Wiring for a trailer
Hi! I want to wire a small trailer to my 1997 RAV4 electrical system.
Where can I make the connections?
Thanks! Bernie
In the back where the trailer hooks up. Sorry but I couldn’t help myself.
Go to a auto parts store and find out if there is a adapter that will just plug into the wiring harness. I believe the brand name of these adapters is HOPPY.
First check-out if there is a factory harness that you can add to the existing harness.
Then see if there is a aftermarket harness offered.
Bernie, It Looks Like A Plug-In Is Available For Your 97 Rav4 !
That would be the easiest, best way to go.
Click on this link:
http://www.trailerwiring.com/
Thanks! I was going to push the trailer. But you were right about the HOPPY plug-in
wiring kit which is available for the RAV4. Bernie
