Why is the battery terminal bolt different for positive & negative
The bolt that clamps down the contact for the negative terminal is 10mm; the bolt on the positive is 11mm. Why? '87 Toyota pickup Xtracab Delux long-bed, carbureted, 5-speed manual, red with white camper shell, green power crystals, platformate,and gl-7 (gets my teeth whiter.)
Are you positive both bolts are the factory original bolts? Maybe the threads on one of the terminal clamps got a little boogered and someone stuck an oversized bolt in there to take up the slack.
Or maybe a 10 mm bolt will not withstand the juice put out by those green power crystals… Red power crystals, 10 mm might work. Green needs 11 mm.
If they’re top-mounted terminals, I’m betting the previous owner replaced one of the battery cables.
If they’re side-mounted terminals, maybe it’s to make sure you don’t hook up the terminals backwards.
Someone may have replaced the metric bolt with a 1/4" bolt, that would have a 7/16" head which is close to 11 mm.
That would be my guess. Just as an aide the bolts are 6mm the nuts should take a 10mm wrench on most Toyota’s.
