I went through the whole multimeter/fuse test to determine where the draw was coming from.
The only spike I saw was on the RDO fuse (I tested all the others just to make sure).
After research I found that (unsurprisingly) the radio is the device connected to the RDO fuse. So I removed the radio. (It’s after-market, BTW)
But the parasitic draw is still present.
I haven’t tested if I still get the spike (should I?).
Is there anything else connected to RDO that would cause the draw?
Thanks in advance.
