What kind of adhesive is used for rubber strips on the outside of a vehicle?
90s Toyotas have a rubber strip around the wheel to protect it from getting hit by someone’s door. It goes in the same place as a fender flare on a truck.
The rubber is shrinking and starting to come off. What kind of adhesive works for this?
Also, the fancy looking silver lining that goes on the outside of the rubber around the back window is coming off. Any recommendations for that?
3M makes a trim adhesive tape for vehicle body moldings.
This product comes in different thicknesses, so you have to decide which one will work best.
3m is prety common adhesive used for rubber stirps. Double sided.
Yep, I have used both the tape and the brush on adhesive depending on the application. Get them where they sell body supplies.
Here’s a tube alternative
Plastic body moldings and sheet metal expand and contract at different rates, that is the reason double-sided adhesive foam molding tape is used for body side moldings.
