The body molding is beginning to peel away near the front door of my car. Any advice on how to secure the molding without a total repalcement?
If I remember correctly, nearly any auto parts store has the proper adhesive. Follow the directions to a T, and you should get good results.
Thanks for your help, I’m off to the parts store
I’ve had good luck with 3M Molding Tape.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_6012221-P_x_x?cm_mmc=CSE--Google--VALUE3-_-VALUE4&ci_src=14110944&ci_sku=6012221
3M is the self-adehesive tape you want to use.
Just make sure the contact areas are clean.
Thanks for the tip
Thanks for the help
Advisor1
