Recently it acted like it might be tied up. a few days later i tried it again and it would turn over, but not start. a few days later i tried again and the same results, each time , the more times i cranked it, the less it wanted to turn over and it would act like it was tied up and would not turn over. Today i installed a new IAC & TPS and it acted the same. I tried the TPS installed incorrectly (where it held the throttle open a little) i know this is wrong but what the hay, nothing worked so far! Well it did start, high RPM and climbing fast, no foot action on the gas pedal. I turned it off and tried again and the same results. I installed the TPS as it should be and it acted the same (Tied uP)
Related topics
| What is causing this? | 8 | 961 | September 8, 2010 | |
| 02 buick rendevous/rpms racing | 4 | 654 | October 21, 2009 | |
| TPS questions | 5 | 522 | January 23, 2021 | |
| 2014 Chrysler 300 - Long Turnover | 5 | 2411 | April 10, 2019 | |
| Can the throttle linkage be sticky? | 75 | 3097 | April 15, 2024 |
