What Could This Be?
I have a 93 mirage es 1.5L. I just finished doing some work on it since it has sat for almost 2 years in my garage.
Heres what was done.
ENGINE New plugs, wires, dist. cap + rotor, oil change x2. New Brakes front rear, Changed old Fuel Filter, drained old gas. Filled half the tank with 87 and used a bottle of injector cleaner.
Here’s my problem
I can start my car with no problem I check my charge with a multi meter I have 15.4V running at idle in driveway and 12.3ish while its off. When I’m driving this car wet, dry I have no problems, until I stop at a light or sign the car dies out after a few seconds my battery light turns on then it dies. I can start it right back up again without a problem and drive it. I was thinking the altenator but the car doesnt die at a idle when its in my driveway. Can anyone give me any tips???
If I clean these 2 items do you think this may fix the problem? I am trying to get away without having to buy these 2 since they will run me about $450
Thanks!
Did you replace the cap, rotor and wires with OEM pieces or aftermarket? Aftermaket ignition parts are hell on those Mitsus.
Well, 12.3 is a bit low for a battery reading while the engine is off. It should be at 12.6.
Each cell should be good for 2.1 volts on a good battery.
The 15.4 is too high a reading even with lighting and accessories turned off.
Is this reading being taken at the battery or the alternator terminal?
I believe you should have the battery charged and load tested as a first step.
I used bosch plugs and wires cap and rotor
this is taken at the battery, while the engine is running I can turn the hazards lights and wipers on and this reading stays the same
Good aftermarket ignition parts are as good or better then OEM ignition parts. I don’t know if you’ve ever looked at ignition parts or not…but there’s NOT a lot of engineering in them. A high-school with a cad and a little knowledge of electronics knowledge can easily design a very high quality one. And it really doesn’t take supurb manufacturing to make one.
