So I have an '03 Volkswagen Jetta 1.8t and I’ve been noticing this noise coming from behind the glove box area while I’m driving. Sounds like something is loose or bouncing around.I posted a video of the noise since I can’t really describe the exact noise.
Has anyone had this problem?
http://www…ZkvRT5GNGs
Assuming I’m hearing what I’m supposed to be hearing (kind of hard to tell based on the audio), you probably have a leaf or small twig or something caught in the blower. First thing I would do (if you haven’t already) is pull the cabin air filter (accessible from the exterior of the car, behind the cowling on the passenger side) and see if you’ve got a bunch of crud in there.
Thank you! I’ll check that out this weekend.
I believe the cabin air filter is located just behind the glove box your car. As riggyrow suggest.
