Water is leaking into my truck!
Hello,
Water is leaking into the rear area of the cab of my truck. It is primarily on the driver side, but I don’t see any water anywhere but the floorboards (nothing on the doors or windows). I was looking into clogged cowl drains, but I didn’t think it would be possible for water to drain out anywhere but the front.
Thanks for any help!
If it seems to be entering the rear of your cab, I would suspect bad seals for your third brake light/cargo light, or a bad rear window seal. Runoff from the roof can enter through either place.
I guess I was mistaken, it is leaking in at the front, but is usually parked slightly uphill so the water was just pooling in the back, so I guess it is cowl drainage issues.
Thanks!
