2003 vw jetta at 75K miles door chime for an open door going off and on and now mostly on when the doors and trunk are closed… how do i clip the feed to the chime
Don’t cut anything. You will only cause yourself problems. The switch should be in the latch so get a can of PB Blast and soak the door latch. See if that helps.
