U0101 Lost Communication with TCM
There may be another fuse involved w/the communication b/t the ecm and the tcm. I can’t tell from here, but check your owners manual, your wiring diagrams. I did some googling and found this for a 2008. Wouldn’t take that long to check all those fuses. In any event be sure to double check fuses associated with the ignition swtich, PCM, TCM, and OBD: both ignition switch fuses 11 & 13, tcm 27, pcm 30, pcm 36, obd 47,
