Trying to identify this
Do you have a volt meter? If so, make some voltage measurements at the battery. Before the first start of the day, should be about 12.6 volts. Then immediately after starting the engine, 13.5-15.5 volts. What do you measure?
Idk I cant start it without jumping it unless I take to to autozone to get recharged the battery completely dead
Battery chargers are pretty inexpensive. If you intend to diy’er work on your car, this is an essential tool.
Oh ok I’ll get one I had no idea I was thinking the cheapest would be somewhere around 150 to 300
So just found out the battery that came with the rv although it’s in good shape it’s a marine battery does that make a difference with alternator charging it?
