I was having trouble getting my '05 Jaguar S-type into gear. After removing the gearbox and disconnecting the linkage, I find that it switches out just fine when pushing and pulling the link end with my hand but the cable seems a bit spongy and has too much “travel” before catching the next gear. Again, it goes into every gear perfectly but I have to push (and, of course, pull) the linkage connector a little too far distance-wise between “P” and “D”. So, when I connect the gearbox and adjust it perfectly for “P”, the shifter won’t move it far enough to reach “D” and vice versa.
Resolved! I jumped under there and noticed that the screw holding the cable mount in place had backed out and was wiggeling like a loose tooth. 5 minutes and a pair of pliars fixed the whole problem! However, while under there, I notices a little fluid around the plastic tranny drain plug. So, I snugged it up and wiped it clean. I’ll check it in a few days and if there’s any leakage, I see a fluid and filter change is in my future. Thanks again.
PS Sorry about the gearbox mix up. I thought about that myself shortly after posting.
