how do i fix a transaxle module fault on a 2004 chrysler concorde lxi, and where is it located? It was put on a diag. machine and came back with the possible cause being a short or open fuse. Can anyone help me?
Sounds obvious, but have you checked the TCM fuse?
well a short fuse,umm! would be open.
why did it short?
what code high fault signal or low signal.(makes a huge difference.
