traction control and abs light on .please help to turn its off. thanks
You need to get the codes read from your car from an autoparts store(free) and post back.
Have you solved the problem that caused these lights to come on?
Disconnect your battery overnight. This may work. But ultimately you have to fix whatever caused the lights to come on.
I had the same trouble on a Buick Skylark, no other symptoms. I took the wheels off, gently pulled the ABS sensors off, cleaned them and the slot they go in. Put everything back in place and the problem cleared up.
