2000 Toyota tundra 4.7 eng.with a engine code p1121 .Fuel Air Metering.Please “HELP”
A fuel/air metering code relates to the O2 sensors.
Tundra Solutions translates P1121
P1121 - Accelerator Pedal Position Sensor Range/Performance Problem
Can you give me any ideas what to do to correct my problem? I have no accel. from 0 to 3/4 gas pedal. It is fine until the engine reaches operating tempt.I’ve replaced the TPS switch.Thanks, Bob
malibu1955
It’s obvious that you didn’t go to the link that BarryNNJ showed you. It shows what other people have done who had this problem. If you read down, you’ll see that the tps (throttle position sensor) is NOT the problem.
