Poor acceleration , rough running and too fast idle
I have a 91 Park avenue which has been giving trouble with the engine not slowing down with the acclerator pedal not depressed at all. Plus Recently it almost stalled when stopped due to too slow idle.
It had also balked when trying to acclerate
from 50 mph. The mechanic said the computer had registered several “TPS” error codes.
Could all these problems stem from a faulty Throttle Position Sensor?
Yep, sure could. And, bunches of other stuff. With a 19 year old car it could be a dried out hose for a vacuum line falling off, or a major problem. It seems the mechanic is on the right track.
Good answer. And to the question; TPS means throttle position sensor so I guess.
