Toyota Corolla has noise when braking
Hi! My Toyota Corolla (2004) sometimes (not always)has noise when braking, but I had the brake pads replaced and rotors resurfaced in December last year. any idea what might be the problems? thanks. Lisa
If the brake rotors were resurfaced it might be time for another brake job.
Brake rotors aren’t resurfaced on a 2004 Corolla when doing a brake job but instead replaced. That’s because the brake rotors are so thin when new that by the time the brake pads wear out the rotors are worn to a point where they’re not worth resurfacing.
Did u do front brakes only or rear brakes as well? Maybe the rears are making noise?
