To buy or not to buy: 2006 Volvo S40
Is this a good car? Would you buy one with over 200k on it?
It is a 12 year old Volvo , where in the world are you going to get parts if you need anything that doesn’t cost an arm and a leg ? 200K , No I wouldn’t . As for how good it is that can’t be determined without seeing the thing in person.
Thank you.
Wholesale Black Book shows $1640. Start deducting for everything it needs. Do you have a local independent shop who will work on old Volvo’s? You can’t afford to take an old Volvo to a dealership.
Is this worth investing $150 or so in a PRE purcahse inspection? Probably not.
This car would probably be near the very bottom of any list of cars I would recommend. Even if someone GIVES it to you it will be costly and troublesome to keep running.
Someone I know had a 1998 Volvo S60(?), I think it was.
It was in the shop all the time, and literally the price of entry was $500 every time.
If you can’t handle that kind of financial hit regularly, don’t know the detailed maintenance history, and/or value your sanity… I’d pass on this one.
Thank you. That seems to be the consensus.
Thanks, given the responses I have gotten I think I will pass.
Are you from Sweden?
If not, don’t buy it. If you are then don’t buy it.
CSA :palm_tree::sunglasses::palm_tree:
