The shift indicator light is out on my Kia spectra 5. Any body actually know what it is? A bulb? A fuze?
Probably a bulb. It’s unlikely there is a separate fuse just for that one bulb. Checking the fuse, however, is always a good place to start.
It has to be the bulb, since all of those indicator bulbs are protected by the same fuse. If you can remove the instrument panel you can get to the bulb.
