My turn signals don’t work. When the proper fuse is connected, the left turn light stays illuminated. I’ve since pulled the fuse, for fear it would drain my battery. Suggestions on how to fix this? I’ve replaced the fuse and checked the battery, both are fine.
You should have a turn signal relay, or a flasher relay
Check your owner’s manual
