Tester--Thank You
The info from http://community.cartalk.com/discussion/2286723/replacing-ac-belt#latest
Was spot on. Everything that I read said “loosen belt”. The sad part was that they did not say “how” to loosen the belt. If you ever make it to the Tampa/St. Pete area, I’ll change your flat tire for you…Thank You
I imagine an early bird special would be more appreciated, @Tester is cool, and if no one else says it thanks for the reply.
Happy to help.
