I have a 92 Toyota Camry.
is it possible to switch the front passenger seat , to the front driver seat?
i want to swap the seats.
the front drivers seat has an electrical motor to adjust the drivers seat. It stopped working.
instead of replacing the motor i wanted to replace it with the passenger seat, that just has a pull type adjustment for leg distance.
is this possible , will the bolts line up? will the track fit?
any and all advice would help.
if YOU DONT KNOW THE ANSWER- can you direct me to the place that could help me find out?? thanks again!
