Strange noise coming from under passenger seat? Gremlin? What is it?
There are small grills in the top. Do you see a green and black wire?
This is not looking the same, no openings, and much larger.
Is it possible that an aftermarket audio system was installed, and that the folks at the dealership aren’t familiar with that system?
Why does it only make noise after 60 mph?
Because the air isn’t going fast enough to make it vibrate below 60 mph.
This is not air noises it sounds like a cable hitting the cover of the the back box.
IIRC Ray & Tom discussed this car on a recent podcast. Ray said while it wasn’t particularly attractive, on the plus-side it was inexpensive, easy to work on, and as long as it received the proper routine maintenance, quite reliable.
Although the manufacturer built the car for low maintenance or cost, Limon can happen for any maker!
Strange noise part 2! See for your self where the noise is coming from under the Passenger seat!
https://youtu.be/i_gVg-OvU84
Strange noise part2
Ummmm, that looks to me just like what Nevada said it was… But Nevada is showing you the back of the seat forward instead of front to back…
I think you’re right.
Link Strange Noise part 3: https://youtu.be/bTSHnVVXuZk
