The steering Wheel of my “1999 BMW 323 I” start shaking when I drive the car on low speed, but once I am on a HWY driving a minimum of 50 MPH and over it stops shaking.
Any advice is very much appreciate it…Thanks
We don’t know what you consider a slow speed. Under 15 mph? If you get wheel shake in the 35-50 mph range, best guess is a bad front tire – internal tread separation or some such. It’s not uncommon for this defect to show up only at some moderate speed but appear normal at higher speeds.
You can test this yourself by rotating the tires front to back. If the wheel shake goes away, you know you have discovered its cause. But then you still have a bad tire that must be replaced.
