took 1963 GTHawk in for frontend alignmentand check and check tightness of all suspension tightness;now powersteering does not work. no problems before.
Not being famliar with the layout on this car, about all I can suggest is that (assuming the belt is proper) that a power steering hose could have been crimped or damaged when the car was pulled onto the alignment rack or someone pried against a line while adjusting something on the front end.
Take it back to the alignment shop…
