'96 Toy Cam (2.2) 71K miles:
intermittent starting problem (in shop 3 times for it, once towed). Wasn’t the battery; wasn’t the distributor/cap; (3rd trip), mechanic said engine flooded & replaced seals…somewhere (wasn’t charged for it & no paperwork).
-low idle (heavy vib up front)
-usually doesn’t respond to more gas or putters out before I can hit gas
-cold or warm engine
-car cuts out instantly/dead when ignition turned off
-no warning lights on dash
-mechanic says computer does not indicate any problem when diagnostic run.
Is there such a thing as a ‘high idle’ adjustment?
Any one recognize the problem?
Thanks.
