'96 Toy Cam (2.2) 71K miles:
 intermittent starting problem (in shop 3 times for it, once towed).  Wasn’t the battery; wasn’t the distributor/cap; (3rd trip), mechanic said engine flooded & replaced seals…somewhere (wasn’t charged for it & no paperwork).
 -low idle (heavy vib up front)
 -usually doesn’t respond to more gas or putters out before I can hit gas
 -cold or warm engine
 -car cuts out instantly/dead when ignition turned off
 -no warning lights on dash
 -mechanic says computer does not indicate any problem when diagnostic run
 Is there such a thing as a ‘high idle’ adjustment?
 Any one recognize the problem?
 Thanks.
