Starter wont come off
Tring to take starter off my 99 town and country. I have all the bolts off have wacked it wont budge any ideas
You are likely missing a bolt that is slightly hidden.
I can look again thanks
There may be 1vertical bolt and 2 horizontal bolts.
Look at the replacement starter to see the bolt holes.
Do you have all three starter bolts out? I believe your starter uses a nose cone that seats in the bell housing (transmission) to keep the gears aligned. I’ve seen those get corroded and stuck. A few well-placed blows with a mallet should loosen things up.
There is a bolt at the top that is invisible. If I remember right it is easier to get to it from above. All three bolts are horizontal. @Cavell has great suggestion to look at replacement.
