Does anyone else have an issue with snap, crackle, pop noises from all the cheap plastic in the dash of their Nissan Sentra? It seems to occur most when the cabin temperature is between 40 & 60 degrees. If you have had the problem, have you figured out a fix? The dealer just says “they all do that”.
I personally own a 2011 Nissan Sentra. I do notice some noise coming from the dash, but have not taken a note of the temperature. I won’t be surprised if it is due to the nasty roads on which I used to drive it in Ohio in combination with the plastic material.
I had a similar issue with a 1965 Rambler Classic 550 from the day I bought it in April of 1965. There was a plastic panel in the center of the dashboard. It was worse at the temperatures you described. I just lived with it for the 8 years I owned the car.
