Squeak 2000 ford focus
I have a 2000 ford focus, that has a squeak when moving. I can bounce the car, engine off, and hear the squeak (s). Sounds like it is coming from under the car.
Any suggestions as to find the source?
Rear brakes are new,including springs.
Thank you!
There are all sorts of rubber bushings in the suspension system that allow various components to pivot. Try taking a can of silicone spray lubricant and soak these bushings with the silicone to see if this will stop the squeaks.
