Speedometer and milage meter not working
I HAVE A 03 HYUNDAI SANTA FE WITH 80,000 MILES ON IT. 2 WEEKS AGO I STOPPED TO GET GAS AND WHEN I STARTED TRUCK UP NOTICE THE SPEEDOMETER WASN’T WORKING. I LOOKED AT ALL FUSES BUT DIDN’T SEE ANYTHING THAT WAS BLOWN. WHAT OTHER POSSIBILTIES COULD IT BE.
Please turn off your caps lock. ALL CAPS IS ANNOYING, and considered to be shouting, which is not nice.
There are fuses in the interior and fuses under the hood. Are you sure you’ve checked them all?
Your car may have a MECHANICAL speedometer drive, a cable connecting the transmission to the speedometer unit. See if you can locate it at the transmission end. You can disconnect it there and manipulate the inner cable and see it you can get the speedometer to respond…
Maybe you can get hold of a scanner or find some way to do a gague sweep to aid your diagnosis.
