To replace the passenger window switch in my 2003 Silhouette,do I need to remove the interior door panel, or will the small plastic switch-plate pop out of the arm rest to allow easier access of the old switch.
You just pop it out with a small screwdriver.
Drivers door? That’s a double switch and is very hard to find (one that works) at a recycler and the dealer should supply a limo for you for what they charge.
