Why does my car vibrate or Shake violently when I turn my heat on or when I shift from Park to drive or when I open my door or close or open my windows
I also get a very strong zap everytime I open and close my door and would like to know why that happenes because it turns off the implant that I have in my back
These are very abnormal symptoms, and would definitely have to be physically seen to give you some kind of accurate diagnosis. Find a good shop and If you can drive or ride with a technician, you should duplicate everything during the test drive.
A ground strap hanging from the bottom of your car will fix you getting zapped from static electricity. The rest of your symptoms are just puzzling.
