Then those jack stands suck They should positively lock. Mine you have to lift the vehicle (all weight off the stand) then you can lift the handle to retract. ,
I would think a cut log (“tree trunk”) of the right size, perhaps 12” diameter by 12” tall would be a lot more cumbersome and likely heavier than a Jack stand,
RE: Concrete blocks
Early in my years as a mechanic in a dealership, an elderly man came in for car service. His face was severely deformed.
He made it a point to pull me aside to explain why he was lucky to be alive. And it was because he used concrete blocks to support a car he worked under decades earlier.
I never forgot that message or his sincerity.
Back to the topic, while I always use good jackstands, if I’ll be under the car for any length of time, I’ll usually put something else next to the jackstands, like blocks of wood, a wheel, or whatever.
the audacity of using a Pittsburgh jack stand to talk about jack stand failures…
Agree…100%
Any of y’all remember the “Andy Letter”, the one about the cattle car call?
To bcohen2010: floor jacks and other hydraulic jacks can blow a seal without warning, it’s happened to me. Use them only for lifting and place a good set of positive locking, appropriately rated jack stands to hold the car (mine are welded, and I inspect them). Years ago a neighbor was killed under his car, I live in earthquake country, someone might bump the car in my driveway, I don’t completely trust any one system and so place an old wheel under the frame near where I’m working as insurance, filling space with plywood squares (not solid lumber which might split).
I mean there’s stories of cars that are very light, e.g. Miata, where somebody was able to accidentally disengage the jackstand.
Honestly, I got Walmart jackstand but that’s why I put the tire under the car ![]()
Thank you. I figure it is not to use as a jackstand, but to be a safety mechanism. It sure would be a bother to move though. You’d have to roll it
