Rt door and trunk well filling with water after rain. Any ideas how/where to check cause of the leak?
trunk rubber seal. most likely knocked off the sheet metal.
also, clean the gutter (around the trunk) free of debris leaves, and pine needles. that stuff clogs the rain from flowing out and encourages runoff to flow into the trunk.
by any chance do you have a antenna, or cable going out the trunk. like the kind for a stick on antenna? those can leak, by having a groove around the rubber seal, which lets water run in too.
bump
