Scion xB "Wet" Chirping sound
After days and days of searching this forum and the internet, I can not find a chirping that exactly fits my situation.
My 2005, automatic, Scion xB makes a very loud chirping sound. I will bullet out as much as i can.
. Only when in drive
. Only while accelerating (pushing on the gas)
. Only happens up to about 1800 rpm
. If I barely, BARELY, press the accelerator, it does not chirp
. Does not chirp in park
. Comes from the engine, not the wheels
. Everyone will say belts, but I had two belts replaced which did not stop it
. It is not a brake noise, I had my brakes replaced
. After driving about 60 minutes, it will be almost non existent
When i was young I had a plastic whistle shaped like a bird that you filled with water. When you blew into it, the water made a chirping, bird like sound. Almost a “wet chirp” which is what this sounds like.
Any help would be greatly appreciated!
