The Wiper transmission bracket has two bolts that stick through the firewall. I need to access the nuts. How can I remove the dash?
The guy at the parts place said there are only two bolts holding the dash…
1995 Saturn SL1.
This might help
http://www1.autozone.com/az/cds/en_us/0900823d/80/19/af/cc/0900823d8019afcc/repairInfoPages.htm
Also check under Chassis Electrical for wiper motor removal/installation.
Ed B.
I have never seen the wiper motor/trans. on this model but also I have never seen a wiper motor/trans that could not be removed throught the cowl vent. Take a closer look. I cannot believe any manuf. would design a car that needs the instrument panel r&i to service this.
step one disconnect batt neg. cable. the guy at the parts place is clueless. step two remove spare tire.???
