2004 Toyota Echo 5-door hatchback (Canadian): Trying to replace the rear wiper arm assembly (VERY expensive)… Struggled - and finally succeeded - to remove the corroded nut that secures the arm in the motor shaft, but apparently the arm mount “cylinder” is similarly corroded to the motor shaft…
Seeking suggestions as to how best I might free this arm and remove it, without compromising the threaded shaft from the motor? I believe the threads are only at the top, where the 10mm nut secures the arm to the shaft… and that the shaft itself is smooth (as is the inside of the blade “cylinder” that slide down over that shaft).
This vehicle shares the identical rear wiper arm assembly/motor with the 2004~2006 Scion Xb models…
Thank you for your time and consideration!
Steve
