I do not have 12 volts on my drivers side window door switch. Fuse is good and the front passenger side window is the only one that works. Drivers side switch and motor are good. Manual says there is a circuit breaker in addition to the fuse. Any ideas? Schematic shows the wire hotting the passenger side is the same wire.
Anyone know where I can get a better Schematic than the one in the haynes manual.
Try the repair manuals on Autozone’s website. You’ll need to register but its easy, free & nonintrusive.
Thanks for the Autozone’s website info.
