2005 Saturn L - Fuse?
MY drivers window has stopped working.
The window will not go up or down , my car is a 2005 Saturn.
I was told that it may be a fuse? I was told the windows run on a motor can you give me some insight?
Any info would be helpful; I really do not want to put a new motor in the car window.
Thanks
3 things prevent windows from working, the fuse, but likely ALL the power windows quit working. The switch and the motor. Those are your choices. Easy to check but it does require the door card to be removed to check.
Or the wiring
