Sable AC
Where’s the low side Ac port on 1995 Mercury Sable 3.0 engine? Thanks
It should be on or near the accumulator, the canister shaped widget that is usually mounted on the passenger side firewall.
If the system is empty then you have a serious leak so if you’re thinking of a quick recharge it probably won’t last. A partial can, maybe. For a while anyway.
Thanks, I guess" I couldn’t see it for Looking"It’s on a sable I gave my mom and so I will check again tomorrow.I think I used to know ,but a stroke erased some of my car repair memory.Thanks
