kraaazzy stuff, unfortunately the details are a bit hazy, have fun with this!
illustrations at the pdf link.
http://org…orce-2.pdf
see also:
http://www…Life-Force
have fun!
THE AWESOME LIFE FORCE by Joseph H.Carter
Section: The Accumulator Device
The following is the most important article the author has ever submitted to any publication
and categorically states is also the most important anyone has ever presented to any
publication. The reasons will become apparent by the time the reader finishes it. Is it possible
that a simple device which can be easily and cheaply mass produced and also easily
constructed by any backyard handyman with no special tools, can put free energy within the
reach of everyone? The answer is an unqualified yes! Incredibly this can be accomplished
without any changes in our pre-sent technology. In a nutshell, it is a device that can be
attached to any internal combustion engine which will obviate the need for fuel. No changes
or alterations of any kind on the engine are required. One standard device of the correct size
will work on any engine, at the same time the engine will perform better than it would on any
fuel. Another dividend is that the exhaust, instead of being toxic, will be highly beneficial. It
will contain much higher negative ion content than ordinary air. Interestingly enough, the old
gasoline engine, long condemned by free energy advocates including the author, can turn out
to be perhaps our greatest and most practical source of free energy.
The ramifications are staggering.
Conventional engines can be used to operate conventional generators, heat homes by its
exhaust and at the same time improve air quality along with many other uses. The only
malefactors directly affected by such changes would be the oil and utility companies.
Ironically the internal combustion engine, ruthlessly preserved by the establishment for nearly
a century can finally be its downfall.
An early clue as to this possibility was revealed to the author several decades ago by an
associate who had witnessed an incredible demonstration. For a period of several months, an
old farmer gave public demonstrations of an ordinary gasoline engine running on air alone.
This was accomplished by passing the air, which eventually went into the manifold, through a
mass of ground up vegetable matter. The engine could be made to run for weeks on one batch.
No doubt, he periodically added water to keep it from drying out. The reader has guessed it.
He finally disappeared under mysterious circumstances.
Later another clue was revealed when it was learned that the engine of diesel trucks often run
wild when they run out of fuel during operation. A former acquaintance of the author
personally witnessed such an event. To remedy this effect some manufacturers have installed
special valve lifters to cut compression when this occurs. In view of the science of soft
particle physics developed by the author and thoroughly explained in his new book “The
Awesome Life Force,” the explanation of the above phenomena becomes self-evident.
As mentioned in previous articles, orgone (or soft electrons) which permeates all known space
is the direct source of all our energy and also electricity. Heat is produced when soft electrons,
which are relatively unstable, disintegrate and release the harder electrons they camouflage.
The released harder electrons produce thermal agitation of atoms and molecules before they
are recaptured. All living things including vegetable matter concentrate soft electrons. When
the air passed through the vegetable matter it picked up high concentrations of soft electrons
before it entered the manifold. The high concentration of soft electrons in the super charged
air became sufficiently agitated during compression and sparking to disintegrate which
resulted in the production of much heat.
In the case of diesel engines, the situation was different but the results were identical. Diesel
engines have ultra high compression ratios and this, coupled with the heat already built up in
the engines during operation, enabled even a lower orgone concentration to disintegrate.
This didn’t occur when the engine was receiving fuel because the atomized fuel absorbed most
1
of the orgone normally present in the air. This prevented excessive agitation and the only heat
released was that due to the burning of the fuel. With this in mind the solution to the problem
of obtaining energy directly from the air without fuel becomes almost self-evident.
A properly constructed orgone accumulator is the greatest concentrator of orgone energy
known. The author is not thinking in terms of just a few alternate layers of metallic and non
metallic substances as has been done in the past but as many as 40 layers! The more layers,
the higher the concentration of orgone results. This means that air passing through an orgone
accumulator with this number of layers will be supercharged sufficiently after it leaves the
accumulator to operate an engine. The size of such an accumulator is also critical. If it is too
small it cannot supply enough orgone to operate a large engine continuously. Orgone is not
concentrated in an accumulator instantaneously after it is exhausted.
The picture is now complete. A box of sufficient size is covered with 40 alternate layers of
aluminum foil and paper. Two thicknesses of newspaper to each layer of foil will be just fine.
In other words, there is one thickness of aluminum foil and the paper to each of the 40 layers.
Except for the openings for the air intake and air outlet, the box is completely lased.
The inside of the box should contain a set of non metallic baffles to disperse the air and cause
it to circulate throughout the entire volume. This enables it to pick up more of the orgone
before it enters the outlet tube. It must also be kept in mind that the outside layer should be
non metallic.
To accommodate the larger automotive engines, the inside volume of the box should be about
11?2 cubic feet. A one-inch outside diameter flex tube will suffice for the outlet line to the
carburetor. A box of this size will not fit under the hood of most cars. It can be placed
anywhere in the car and the flex line from the outlet can be routed to the engine. It should also
be apparent to the reader that despite what it can do it is also the epitome of simplicity.
The author was recently introduced to a mineral processor who is also a top dowser. He uses
his dowsing ability to pick out the chemicals he needs for any specific purpose and to
determine other things he needs to know with uncanny accuracy. He dowsed out questions put
to him concerning this new device and the answers he received closely parallels the author’s
own determinations.
His conclusions were as follows: Yes, the device will definitely work; 30 alternate layers of
aluminum foil and paper or 26 using copper foil will do the job. The volume of the box should
be at least 11?4 cubic feet. The input and output lines can be 1?2 inch inside diameter. The author
neglected to ask if this would suffice under all conditions; however, to insure top performance
under the worst of conditions when the orgone concentration in the atmosphere is relatively
low, the author recommends the specifications as he originally laid down.
The author has demonstrated the potency of a multi-layered accumulator by covering a water
jug with 18 alternate layers of copper foil and newspaper. The water from this jug is unique. It
is vastly superior to water treated in any other way, including water placed under a pyramid. It
has a sweet taste and has proven to be completely free of all impurities. Impurities settle to the
bottom of the container and those who drink the water can cut down drastically on food
intake. For treating water, copper should be used instead of aluminum since it has a more
beneficial radiation which is absorbed by the water. The author now plans to cover a one-
gallon glass jug with 30 layers of copper foil and paper.
2
Cross section of original device.
If the reader plans to build either or both of the above devices, he will find that ordinary
masking tape is effective for securing each layer.
Enclosed is the latest on this device.
3
Improved version accumulator device
This new
design has
been dowsed
out as better
than the
original. I
expect to
have a
sensational
announce-
ment to
make soon.
A close
friend is
starting the
construction
of one. What
this could do
for the book
is staggering.
To those who wish to build the device analyzed in my article showing how to derive free
energy directly from the atmosphere and want ‘more’ detail, a step by step description will
now be given.
In the author’s article, he had neglected to mention the number of baffles required.
For a unit 12? by 12? and 18?long at least 40 baffles would be needed for efficient operation.
However, since then the author has devised a greatly improved version which will also be
much easier to build.
The box housing the device can be constructed of heavy Plexiglas. For a unit 12" x 12" x 18"
use four thick sheets of Plexiglas 12" x 18" and two 12" x 12". For the pieces to fit properly
the two 12 x 12 ends should be twice the thickness of the Plexiglas less than 12 inches on a
side. The box can be put together with epoxy glue. It must be sturdy to withstand stresses
resulting from the partial vacuum produced by suction of engine. Before the top sheet is glued
on, a perforated baffle is inserted 1/4 inch from bottom of box producing a false-bottom. (1/4
inch spacers can be placed on bottom of box). It is completely sealed along all four sides to
the sides of the box. This baffle has 250 to 300 1/16 inch diameter holes drilled into it, equally
distributed throughout its area. When all of this is accomplished, the box is filled with fiber
glass wool and packed in the manner of ordinary insulation. It must be pushed tightly against
the sides of the box so incoming air won’t find an easy outlet. The fiberglass fills the box to
within 1/4 inch from the top. Another perforated sheet identical to the bottom one is now
placed over the wool and completely sealed on all four sides to the inside of the box.
The heavy Plexiglas top is now attached to the box.
Both the top and bottom plates have 1 inch diameter holes to which are attached one inch
diameter tubes for the input and outlet flow of air.
The 40 layers of aluminum foil and paper can be most easily applied to the outside in the
4
following manner.
Four 12 x 18 sheets and two 12 x 12 sheets of Plexiglas are cut. On these separate sheets are
placed the 40 layers of aluminum foil and paper. However, it is done in the following manner.
If two thicknesses of newspaper to each layer of aluminum foil is to be used then 80
thicknesses of newspaper and 40 layers of aluminum foil are laid out and then cut to the right
dimensions. For two of the 12 x 18 sheets these layers will overlap on all four sides by an
amount equal to the thickness of 40 layers of paper and aluminum. The other two 12 x 18
sheets will be overlapped only on the 12 inch ends. There will be no overlapping on the 12 x
12 sheets. With the layers of paper and aluminum cut to the right dimensions, they can be
quickly applied to the sheets. Each layer is secured with a spot of ordinary glue in three or
four places. When all six sheets are covered, they are then fitted and glued to the box and then
secured with a generous amount of masking tape. The top and bottom portions of course have
one inch holes drilled in them so they will fit over the inlet and outlet tubes.
When in operation, the inlet and outlet air must pass through all the small holes in the
perforated baffles. This insures a uniform distribution of air flow throughout the fiberglass
wool which is loose enough to insure the passage of the air without excessive restriction.
There shouldn?t be any problem in stopping the motor. In case such a problem did arise, and
shutting off the ignition didn’t do it, a hand choke could be installed to completely shut off the
air.
Of course the throttle would obviously control RPM as it does with fuel. In the case of Diesel
engines running wild, enough air got around the ‘closed’ throttle to power the engine. Once
again a choke that would completely close off the air would have done the job.
In the above construction it must be emphasized that the proper packing of the glass is of
paramount importance. It must be packed to the extent that the passage of air begins to be
seriously restricted. Up to this point the tighter it is packed the better. The more wool, the
greater the surface area of highly concentrated orgone exposed to the air flow and at the same
time the greater the dispersion of air which is vital. If this is not followed, failure will more
than likely result. The orgone box should be constructed so that the top can be easily removed
or put back on.
The above method of construction can be followed by those who wish to use the box for
converting otherwise impotent electric generators or free energy devices into highly potent
ones. The box can also be used for energizing and purifying water or preserving food. In the
latter case it will be more effective than any refrigerator.
The author covered a gallon glass jug with 30 alternate layers of copper foil and paper. The
water from it is phenomenal. Even a stainless steel blade placed in a cup of this water soon
becomes magnetized! It has dowsed out that this water has the power to rejuvenate if used
regularly. The bottle is filled once a day and should be cleaned out once a month because of
impurities that precipitate out and settle to the bottom.
Joseph H. Cater
Copyright ? 1985
HEALTH RESEARCH, Box 70, Mokelumne Hill, California 95245
I’ve “flagged” this as “inappropriate”. Anyone care to join me so we can get this Bozo off our forum?
