Right rear inside door panel 2001 grand marques
How do I remove the door panel. The door latch has come loose or broke from inside the door and i can no longer open the door from the inside. I removed the two screws for the door pull handle and the one screw from the bottom of the panel but it would not move.
There should be a series of plastic clips spaced about 5-6 inches apart all the way around the perimiter of the panel.
You can buy a tool made for removing these clips or use something else thin to pry the top clips loose.
There is a very good chance the clips will break so have some new ones handy.
Once the top and side clips are free, lift the panel out and up.
