ABS light on, can it be reset or is there a solution?
Sure it can be reset… but if the problem is still there, it will come back on. The solution is to fix what broke to turn the light on in the first place.
That’s how warning lights work on cars. Something that needs fixing turns a light on or posts a message telling you to service some part of the car. If the light is flashing, that means really bad things are happening. Then you should pull over, stop, turn the engine off and have it towed before really expensive things need replacing.
Thanks for in information. That I already knew.
Mail](https://go.microsoft.com/fwlink/?LinkId=550986) for Windows 10
Then why did you ask?
