So I’m looking to replace the stereo of my 2003 Honda Pilot and this may be a stupid question but do I need some sort of converter to switch a new stereo I picked out with the old one? It just looks like the two have different adaptors for actually plugging into the car and I wasn’t sure if there was something else I needed to make this work.
Thanks
New stereo:
Old one:
http://www.ebay.com/itm/like/170751623519?lpid=82
If you use Crutchfield they will supply you with the needed connectors and instructions. Just make sure they know the make/model/etc you’re buying for.
The adapter connector and wires it to the new connector supplied with the radio. Then you plug it directly to th existing car wiring connector. That way the cars wiring stays the same. It comes with the harness from Crutchfield http://www.crutchfield.com/p_120701721/Metra-70-1721-Receiver-Wiring-Harness.html
There is a warning
Installation Details for your 2003 Honda Pilot Sport Utility with Navigation system
To install this item, you’ll have to modify your vehicle.
Installing a new car stereo in your vehicle requires fabricating a trim plate. You may want to consult a car audio professional.
When you replace the factory radio, the factory navigation system won’t work anymore.
When you replace the factory radio, the factory subwoofer won’t work anymore.
You’ll need to use the factory radio’s brackets in order to install your new receiver. If you don’t have the brackets, you can obtain them from your dealership.
