These frigid WI temps are horrible. I did end up washing my car last weekend because it was full of salt. This morning I pressed the lock on my remote 2 times, nothing happened. Normally the horn sounds off once and the lights flash. I seen the lights flash, but there was no sound coming from the horn…frozen locks?
I came home after work and tried it again. Works fine now.
Usually the batteries in the FOB lasts longer than a year. Your hypothesis is probably correct. However, we had both FOBs on our 2003 4Runner doing what your FOB is doing. For a total price of under $5, I bought replacement batteries at WalMart (found them in the jewelry section) and even in this frigid weather have had no more problem. If your problem reoccurs, buy new batteries. They are cheap and easy to install.
If the lights flashed, the car received the signal. This would rule out the battery in the key fob. If the horn works normally but didn’t in this instance, I would think that you had some kind of glitch with the body controller module or other module that handles the remote functions. It might have somehow been water that got in to something, or possibly extreme cold. Extreme cold wreaks havoc with all kinds of things.
Another possibility is that the car battery was low or a poor connection existed somewhere so that there was enough power for the system to be “conscious” and receive the signal, but not enough to actuate the horn or locks. Checking and cleaning the battery terminals is probably a good idea, as someone else has mentioned.
