Odd noise coming from the rear end or maybe transmission, sounds like big tires. Speed does not seem to make a differance. Not sure if its a rear main seal or gearing issue. Help! Thank You.
I would let a good mechanic check your rear axle for bad wheel bearings. Something is making a noise for a reason so have it checked out.
