Real noob question, you will laugh haha - But I have no clue and I have to ask
So I got a gas can like this. Now my question is the small yellow cap at the back. Is that supposed to be on tight so it seals. So if I blow in the front no air should be escaping from the back cap? Is that just a hole to open when you pour gas so it doesn’t glug glug? I thought that was the point of the special self venting spout…
It’s called a vent cap.
You open it when you pour gas out of the can.
You’d think that self-venting design for the spout would eliminate the need for another vent. But it appears from the photo the self venting design is geared more for lower flow rate pouring; if you were trying to pour gas as fast as possible the space around the outlet might all get filled with liquid gasoline and the self-venting spout idea wouldn’t work.
You can buy those little plastic caps on ebay. I have added them to all my plastic cas cans because all the self venting spouts don’t work wort a hoot. You just drill a 1/2 " hole with a spade bit and pop them in.
You use the self-venting nozzle when filling things like lawn mowers, snow throwers, etc…
But if you use the gas can to add gas to a modern vehicle gas tank, the ORVR system won’t allow the gas can to vent properly. So you open the vent cap.
It’s an EPA thing.
Ok thanks guys :slightly_smiling_face:
So keep it shut tight when it’s in storage so no water get in the ethanol mix?
gas%20can
Always add a fuel stabilizer such as Sta-Bil when storing gasoline.
It’s only going to maximum 1 month maybe. It’s E85 so it’s even less store able right?
Would you recommend it’s for 1 month?
What do you have that can use E85 . I know your BMW can’t . I certainly would not put it in lawnmower.
Soooo?
Are you planning to use that E85 gas in a flex-fuel vehicle?
It’s to run E fuel mix maps on my car.
E85 is rare in Canada. This “local” sports club 40 mins away sell some. I only plan to use it at drag days at my local track so having a 20 litre few weeks before for when I go will give me a full tank of E30 mix when mixed properly.
Yes it can.
Alcohol drag racing?
You’re good to go.
The gas can will work.
Alcohol lasts a mighty long time.
http://www.fuel-testers.com/expiration_of_ethanol_gas.html
Yeah but I’ve been told E85 has a tedency to absob water, kinda like brake fluid.
So the container has to be saeled really really well.
