The driver and passenger side windows on my Alero stopped working at the exact same time. We checked the fuse and replaced it and it still didn’t work. Both of the window regulators were replaced last year, and there is no noise at all when you press the buttons. The driver’s side window is stuck open, and it gets pretty chilly.
Please help!
Check for power TO the fuse.
There may be a broken/damaged or loose wire to the main power window switch.
